Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 01-24-2016, 10:32 PM
rioredstang rioredstang is offline
Looking for wheels
I'm looking for a larger set of wheels. Anybody have anything? I have 18x9.5 BBS
Old 02-17-2016, 07:13 PM
bbenavitz bbenavitz is offline
Re: Looking for wheels
If you have the original bbs RG776H in decent condition I would like to buy them. If you are interested email me at [email protected]
Old 02-17-2016, 07:52 PM
I have the original wheels. I am looking for a extra set. I would like to find some 12" wide wheels. I would like a little more tire for the back. Maybe a 305/680. I am still measuring to see what will work. I may talk to Bob about some BBS wheels.
Old 06-02-2016, 10:05 AM
panozracing's Avatar
panozracing panozracing is offline
I run 11" front (305/65) and 12" rears (325/70) Michelin slicks. You will love it but you need to be FAST otherwise you wont get the heat in the tires and it will hurt performance.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 06-02-2016, 10:00 PM
What brand of wheels and offset do you have? I have seen wheels break before. I want a wheel that is safe for our cars.
Old 06-05-2016, 10:29 AM
CCW Wheels. I use the same backspace on all 4 corners which I think is 7.25" and I use a thick spacer up front and a very thin one in the rear. The front is probably 5/8 thick and the rear is probably 1/8". the reasoning was so that If I ever wanted to run the same size rim all the way around I have that option. If you call CCW in Florida and speak with John he should be able to help you. I use the 3 pc classic wheel even though they are softer/damage easier because I can replace parts rather then the entire wheel. They have never bent from use only contact. I have been using them for 10 years plus of racing.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 06-05-2016, 08:52 PM
ITRCiViCC ITRCiViCC is offline
If you buy my GTS, it comes with 2 sets of CCW wheels (both have 12 inch wide rears) in addition to the original BBS. I am sure you don't want to buy a whole car for wheels, but CCW will make them for you for around $875 each. They are pricey, but very nice, light wheels.
Old 06-06-2016, 02:41 PM
Do you have fender flares or do they fit under stock fenders?
Old 06-06-2016, 10:44 PM
No flares. If you want to see some photos of them, have a look at the ads for my car posted on the forum. No scrubbing either.
