Old 07-01-2003, 07:33 AM
canul8r canul8r is offline
Angry Interesting problem, or not
Was having problem with my temp gauge not registering above 150 degrees. thought maybe my thermostat was missing, flushed my cooling system and low and behold my gauge was reading around 200 - 210 degrees and then would drop to about 180. Then, it went back to its old trick of not reading above 150. I noticed that while all this is going on, the oil gauge fluctuates between 60 - 80 and pegs out under load. The gas gauge fluctuates also. So, in short, when the temp is at 150 the oil and gas gauge fluctuates and when the temp gauge is reading 180 -210 the oil and gas gauge read normal. Any ideas? Thanks for help in advance.
Old 07-02-2003, 11:58 AM
that1guy that1guy is offline
just a thought. when is the last time you checked or changed your oil?
Old 07-02-2003, 12:56 PM
Monday. The same day I had the power flush done.
Old 07-02-2003, 01:56 PM
id maybe try replacing the thermostat. Other than that, I'm not sure.
Old 07-02-2003, 02:23 PM
Thanks, that was my next move plus I was told to get rid of the red c**p out of my radiator and replace it with green.
Old 07-02-2003, 02:43 PM
that would be a good idea too
