Old 01-21-2016, 11:42 PM
itrgtr's Avatar
itrgtr itrgtr is offline
Aoshima 1/24 Rocket Bunny 86
It's been about 10 years since I last built a model. I got an airbrush as a gift, so figured I would try it out.
here's the kit
first piece i started out with was the exhaust. Going for burnt titanium look.
primered the chassis
this is tamiya clear red on gold. looks uneven because some areas masked off, and others only lightly coated as I will be painting it another color.
more to come later
Old 01-23-2016, 09:18 AM
itrgtr's Avatar
Re: Aoshima 1/24 Rocket Bunny 86
Old 01-24-2016, 12:30 PM
koooba's Avatar
koooba koooba is offline
nice. I just did this kit myself (it also was my first modelling project since 15 years) and I am looking forward to follow the progress on your build.
Old 01-24-2016, 12:50 PM
itrgtr's Avatar
Thanks. I saw yours too, nice work! I am a bit surprised there was no engine in this kit.
Old 01-24-2016, 01:28 PM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
i like the color you chose (clear red over gold). i've built one too, though it was a special version from a local hobby shop (they became aoshima's exclusive distributor) - it was the stock 86 (with engine - best car GT 103), then in another box were the rocket bunny parts. the kit is a joy to build, although i didn't like the window masks as paint bled under it (not sure why though, surface was clean and i pressed down the edges a couple of times).
olly olly oxen free
Old 02-02-2016, 05:13 PM
itrgtr's Avatar
a few updates.
Old 02-04-2016, 08:28 PM
itrgtr's Avatar
finally done with the chassis.
Old 02-06-2016, 12:28 AM
MidMazar's Avatar
MidMazar MidMazar is offline
The chassis was painted really well, keep us posted.
In Progress
Old 02-06-2016, 04:15 AM
koooba's Avatar
looks fantastic!
Old 02-07-2016, 03:16 PM
itrgtr's Avatar
Thanks guys. started some work on the body. Requires cutting the fenders to fit the widebody.
Old 02-10-2016, 02:51 AM
circuitR's Avatar
circuitR circuitR is offline
Thanks for sharing how you went about cutting the fenders. One day I'll get this kit lol
Check out my
Instagram
Old 02-10-2016, 06:57 PM
itrgtr's Avatar
ok, question for anybody about clear coating:
I used to clear my models with future floor wax, but bought tamiya x-13 clear this time. I'm reading that I should either spray it about 15 mins after my color coat, or wait 30 days as the difference in drying can cause cracking in the clear coat.
My question has to do with decals. I plan to apply color coat, decal, then clear coat. But if I do it that way, I can't imaging it being a good idea applying decal on fresh paint? Am I pretty much only left with the option of apply clear after waiting 30 days?
Also it seems that consensus is that a couple of light coats followed by heavy coat should be fine. Thoughts?
Old 02-10-2016, 07:55 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Nice work so far!
X-13 is acrylic metallic blue. Do you mean TS-13, synthetic clear lacquer in a spray can?
That regimen applies only to enamel paints. Lacquers and acrylics don't have that limitation. The one most important thing you should know about TS13 is that it is very "hot"- it contains a significant amount of lacquer solvent. It can produce terrific results, but it requires care and patience. Take plenty of time between coats (hours or days), and build it up in many light coats. Do not spray it in heavy, wet coats- especially over decals or metallic paint. Much better six or eight light coats over several days than one or two wet coats.
Spray one or two light mist coats, and give them overnight to dry. Apply your decals, and let them sit again overnight. Then start building up light mist coats over top of the decals. Apply a light coat, wait an hour or two, then another mist coat. Once you have a few solid layers safely built over your decals, you can apply two mist coats at a time. But if you let this stuff go on wet, it will eat your decals- and possibly the paint as well.
Mist coats generally dry with a bit of a haze. This doesn't matter at all except for the final coat. Spray the final coat just like all the others, and then let the body sit for a week to outgas. Then take some Tamiya coarse compound and a soft cloth and polish away the haze.
PHOTOBUCKET SUCKS
Old 02-10-2016, 08:58 PM
itrgtr's Avatar
Originally Posted by MPWR View Post
Nice work so far!
Sorry, yes TS-13 is what I mean't. But thank you for the quick reply, I'll give that a try and report back!
Old 02-11-2016, 09:30 AM
did you use masking tape for the underchassis, or masking putty?
olly olly oxen free
