Old 01-19-2016, 10:44 PM
fenderfixer fenderfixer is offline
2005 GP intermittent start issues
my 05 GP randomly decides not to start. it turns over well but no fire . Sometimes even when I just stop for gas when its already warm. if I leave it for a few minutes usually it will start, run a little rough for a minute then run fine till next episode. no faults show up. I was thinking maybe the fuel pump relay was acting up but thought I'd get some feedback before I dove in.
Old 01-19-2016, 11:16 PM
Tech II Tech II is offline
Re: 2005 GP intermittent start issues
When it won't start, you have to determine if it's fuel problem, a spark problem, or air flow problem.....
Some things you can quickly check.....
Pull the vac line to the f/p regulator, and look for fuel in the vac line.....
Disconnect the MAF....if it starts, you probably need a new one....
Slightly step on the accel pedal and see if it starts.....
Otherwise check fuel pressure and spark.....
Old 01-20-2016, 04:56 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Check the throttle body. They like to gum up and get extremely dirty. When dirty the car might not start correctly.
