Old 01-18-2016, 06:24 AM
evelethed evelethed is offline
town and country 2003 not shifting into 3rd or 4th
Hi i need someone to throw me a bone (idea) changed input and output sensor, replaced solenoid pack, cam and crank sensor. Runs good code on odometer 1684 p700 still not shifting
Old 06-04-2017, 06:07 PM
cowboystuff cowboystuff is offline
Re: town and country 2003 not shifting into 3rd or 4th
OBD II scanner should enlighten you somewhat. Have you tested the TCM, or replaced it?
Old 06-05-2017, 12:10 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
The P0700 is telling you the TCM is telling the PCM it has recorded a transmission fault code. You have to read the code using a scanner designed to read transmission codes. Any transmission shop or dealer can read it for you.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
