Old 01-18-2016, 12:08 AM
scott198910 scott198910 is offline
Exclamation 1999 Grand am pon
After the cold hit last night I turned my car on and it starts to shake a lot, also white smoke so I drove it to work while driving it takes forever to pick up speed and jumps speeds on rpm while shaking a lot and then I got off work and now its so hard to turn the wheel now(I put in steering fluid) and still shakes badly. I smelt burning kinda before work and I no I'm due for oil change so I just put oil in atm bcuz I have no time to take it any where atm since I work to full time jobs. Also the Trac off light is on and my service engine light is blinking. Any. Help will be nice soon I gotta walk to work tomorrow morning so cold.
Old 01-18-2016, 09:23 AM
Tech II Tech II is offline
Re: 1999 Grand am pon
You have some major problems here....
A major one, is the blinking check engine light....that means you have a serious misfire.....
Old 01-19-2016, 08:14 AM
MikeCStig MikeCStig is offline
I'm sorry to say, a misfire may only be the beginning of the problem(s) with your car. The burning smell and white smoke are potential indicators of a blown head gasket. Having been through one of these myself, I know that it's quite a task. The parts needed for this usually aren't that expensive, but the labor is another story. If you were to do it yourself (warning: it's not easy) you'd save a lot of money, but if you pay a shop to do the job, it can get pretty expensive.
Another concern I would have is how long has it been since your last oil change? Running an engine on overused oil can cause some serious damage too.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
