Go Back   Automotive Forums Car Chat > Hyundai > Santa Fe > MY 01-06
Old 01-16-2016, 08:58 PM
Waleygator Waleygator is offline
2005 Power antenna problem
Just purchased a 2005 Santa Fe today with electric rear antenna. Supposed to extend when radio is turned on, then descend when shut off. I hear 8 "clicks" from the antenna area each time, but the antenna itself doesn't move. Any suggestion other than replacement? Thanks in advance...
Old 01-17-2016, 12:35 PM
MikeCStig MikeCStig is offline
Re: 2005 Power antenna problem
I'm sorry to say that in my experience what you're describing sounds like a jammed antenna, it's probably bent. Unfortunately it's not even worth trying to straighten the antenna out because it probably won't even work. Replacement is the answer.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
