Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-12-2016, 05:29 PM
crown03 crown03 is offline
2003 Crown Victoria Hesitation.
Hello, I am new to this forum which was recommended to me by a friend. I have a 2003 Ford crown Victoria with 137,000km (85,000 miles) which is in good condition overall. It runs well in the city and highway with few problems. I have noticed 1 issue with this car that is consistent. When it is snowing and below freezing it will hesitate occasionally on the highway at speeds over 45 mph. It does not put out any codes. I have sprayed the ignition wires with no change. I have not changed any ignition parts. I did over 500 miles on the highway this weekend in moderate rain with no trouble at all at temperatures around freezing. Today was snowing and below freezing with same problem on highway with occasional hesitation. In the city today with traction problems and tires spinning the ABS and Brake light came on. They were out when I drove it home. I live in the greater Toronto area.
Any help on this would be greatly appreciated.
Thank you, Allan
Old 01-15-2016, 07:12 AM
rhandwor rhandwor is offline
Re: 2003 Crown Victoria Hesitation.
Go to an Auto store with loaner tools and get a fuel pressure test gauge set. Check fuel pressure low fuel pressure can cause problem.
When did you change fuel filter. Some parts stores will scan your system free get this done. If you don't find anything reply back. Pull vacuum line on fuel pressure regulator if fuel in the line replace.
Old 01-16-2016, 12:06 PM
Thank you for advice. I have not changed fuel filter since I bought car in Sept 2014. I will change it and test the pressure and let you know how it goes. It may take a while as it only does it in specific conditions.
Old 02-22-2016, 07:07 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Second the fuel pressure idea. Fuel filter is usually the culprit. You will need a tool to get the quick disconnect loose for each end of the filter.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
