Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 01-06-2016, 08:26 PM
smothers12 smothers12 is offline
Turn signals & brake lights
I have an 85 K1500 that I use as a plow truck. I noticed yesterday that I no longer have turn signals or brake lights (tail lights work just fine). I checked the fuse under the dash and it is not blown. Just in case, I replaced the fuse and the flasher. That didn't fix it. I wouldn't think it would be a relay since the brake lights aren't working either.
Are there fuses anywhere else that I could be missing? Any other ideas?
Old 01-07-2016, 05:34 PM
777stickman 777stickman is offline
Re: Turn signals & brake lights
Do the front signals work? Do the hazards work? There may be another fuse marked TURN/BU.
The stop/turn lites in the back use the same bulbs and wiring from the front. Check the rear grounds for those bulbs.
This is out of my '88 manual.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 01-07-2016, 05:43 PM
paulfromoh's Avatar
paulfromoh paulfromoh is offline
If the front signals work, youll need to check the bulbs too... If one has been out for a while you may not have noticed till the other one went bad.
Tags
brakes , electrical , signals
