Old 01-06-2016, 06:07 PM
Thetonk Thetonk is offline
Cold start issues
I'm having a problem. I have an '06 trailblazer with the 5.3 engine. When it's cold outside Freezing and below. The engine will start. Run for three seconds. And shutdown. Pass lock light stays solid. The engine won't crank for about a minute. And it'll do the same thing. If it's about 40 or above. No problems. Any ideas?
Old 01-07-2016, 03:05 AM
MikeCStig MikeCStig is offline
Re: Cold start issues
Cold starts can be a problem in any vehicle. You're asking your engine to fire up under conditions that it doesn't like and if it's ridiculously cold it may disobey. Here are some things that have worked for me.
-Turn the ignition on (don't start the engine) wait 5 seconds for the fuel pump to build pressure, then shut it all off. Repeat this process one more time, then do it a third time, but this time after you allow the fuel pump to prime, start the engine
-When the engine starts, give it a little throttle, and keep giving it throttle until you're confident that it will run on its own, don't drive until the engine is fully warmed up.
-When it's cold, run premium fuel or use an octane booster. I'm running premium right now and my car doesn't even require it, but I live in Maine and it's f**king cold up here!
So there are some ideas and I hope one of them helps, good luck.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 01-07-2016, 10:39 AM
Schurkey Schurkey is offline
I'd suggest investigating the PassLock system.
GM runs the fuel pump for two seconds to pressurize the fuel system when the key is turned from "Off" to "On". If this two-second "head start" for the fuel pump isn't sufficient, it indicates a fault in the fuel pump wiring, the fuel pump, or the fuel system check valve that retains pressure in the fuel system after the pump has shut off.
Indicates a fault in the idle-speed control system--the Idle Air Control valve or the wiring to it. There is no need to "warm up" an engine before driving, or to stabilize the idle with the gas pedal. Even ancient carburetors had a fast-idle cam.
Completely un-needed. A cold engine is unlikely to detonate, and that would be the reason to increase the octane rating.
A carbureted or throttle-body injected engine would appreciate gasoline blended for low temperature vaporization. This is done by the refinery for gasoline sold in any climate needing the cold-weather gasoline. If your vehicle doesn't run right in very cold weather--and you've still got gasoline in the tank from the summer before--it may run poorly when cold.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 01-09-2016, 09:37 AM
Well it warmed up enough for me to get over to my buddy's shop to scan the computer. P0601 code which indicates an internal fault in the Pcm. I've recently found 7 other threads with the exact same symptoms stating people replaced their pcm. Problem solved. So. Pcm enroute
Old 01-09-2016, 01:00 PM
paulfromoh's Avatar
paulfromoh paulfromoh is offline
My 03 avalanche kept throwing a PCM and Mass air flow sensor code. Because the whole thing is run by a computer, it would cause the engine to run too rich and it would run like crap once the code was on.
My solution was to erase the code and it would run fine for a few days. I ended up cleaning the mass flow and replacing the pcm but neither worked. The final solution was just a basic tune up with new plugs, wires etc.
Old 01-28-2016, 08:31 PM
Lms2015 Lms2015 is offline
I am having the same issue. When it's cold outside my trailblazer will fire up for about 5 to 10 seconds and completely shut off. Even if you rev the engine up it still stalls. Strange thing is, if the temperature is above freezing but below 50 degrees you can heat the key up, start it up and it will stay running as long as the inside of the car stays warm it will stay running - if the inside gets cold it shuts off again. If it's above 50 degrees outside it starts and runs with no problem. It's been in the shop for 2 weeks and they still can't figure it out. They are leaning towards replacing the computer but unsure if that's really it. Mine is also an 06. New battery, alternator, ignition switch and key switch. Any ideas??
Old 01-29-2016, 10:28 AM
Replace the key???
Replace the lock cylinder???
Old 01-29-2016, 11:02 AM
Mine was the pcm
