Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 01-05-2016, 09:40 PM
searchlight4759 searchlight4759 is offline
1997 - Heat but not Hot at Maximum Setting
I have 1997 Sable Vulcan 3.0. Had the infamous no heat problem, and had a radiator and heater core flush.
After doing that, the heat returned, almost hot at maximum.
That was three months ago.
Now it is January with 18 degree weather. I get heat but even at Maximum it is very warm but not hot.
Is this type of heat production typical of this car or do I need to have another flush done of the system and/or heater core.
The temperature gauge rises to the safe zone as I am driving the car and stays roughly in the lower third of the gauge. It never drops as the car is running.
I also checked the ac heat blend control door mechanism and it works fine as I see the silver lever move completely from one end to the other as I turn the temp dial from cool to max heat. I even sprayed some WD40 on it for good measure.
Otherwise the car runs very smoothly.
Your thoughts please?
