Go Back   Automotive Forums Car Chat > Jeep > Liberty
Old 01-04-2016, 12:06 PM
toddw260 toddw260 is offline
03 Liberty Engine Noise
My 03 Liberty makes a rattling noise at the front of the engine. It is a 3.6L V6 with 185K miles on it.
The mechanic that we take the car to said we need to replace the timing chains. We have had AC problems and I thought is might be the compressor. I removed the serpentine belt and the noise persisted.
Based on experience with motorcycles, it sounds like a loose chain. The noise varies with engine speed. You can here the vehicle coming from a couple hundred feet away.
The previous post I could find in this forum referred to people getting 250K+ miles without timing chain replacement.
Anybody else experienced a similar noise.
Thanks
Old 01-04-2016, 07:36 PM
MikeCStig MikeCStig is offline
Re: 03 Liberty Engine Noise
Anyone you've spoken to who got 250k or more out of a timing chain is lucky. Those chains wear out, the links expand over time, the rollers wear out and that results in the chain loosening up. If your timing chain is making noise, replace it, you definitely don't want it to break.
Remember, a chain (of any kind) is only as strong as its weakest link.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 01-14-2016, 07:25 AM
rhandwor rhandwor is offline
Use a stethoscope and listen to the covers for the chain you can probably hear rubbing. When replacing buy the full set with guides and tensioners.
