Old 01-04-2016, 05:48 AM
joelwideqvist joelwideqvist is offline
Possible to use old Zero paint?
I have an unopened glass bottle with Zero paint that is seven years old.
I guess it has thickened over the years and I read at hiroboy that shelf life is just one or two years.
Would it be possible to use it if I add the appropriate amount of thinner or is it other factors that get altered over the years. I've read that old laquer clear can crack for example.
Old 01-04-2016, 12:17 PM
modellmaker.'s Avatar
modellmaker. modellmaker. is offline
Re: Possible to use old Zero paint?
Hi,
Maybe it's easier to send an email to Steve Hemming.
He's the man behind Zero-Paint and Hiroboy
I'm sure he can give you the correct answer.
modellmaker
Twitter, Instagram: #modellmaker
Old 01-04-2016, 12:25 PM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
YES.
I used several old Zeros stored on their old kind plastic bottles: inside there was just solid stuff... no liquid, all the solvent was evaporated: I just added a good solvent for industrial acrylics (those used on 2K acrylic clear like the Zero, you may eventually use the specific zero paint solvent as well), shaked well and..... magic, like new. I don't know if it works for metalized Zeros also, I done on solid red and black.
gio
The Following User Says Thank You to gionc For This Useful Post:
joelwideqvist (01-04-2016)
Old 01-04-2016, 12:26 PM
gionc's Avatar
Authorized Vendor
PS: can't assure you that you wouldn't meet cracks or other stuf. it worked for me overa primer and under a clear.....
gio
Old 01-05-2016, 08:27 AM
mchernecki mchernecki is offline
Just get more thinner/reducers from Zero paint and you should be fine. Just be sure of what paint you have as Zero has both lacquer thinner and basecoat reducer. Contact Zero and they will tell you which thinner/reducer you need.
The Following User Says Thank You to mchernecki For This Useful Post:
joelwideqvist (01-10-2016)
Old 01-10-2016, 12:05 PM
John18d John18d is offline
Hi Joel
Yes I have still used Zero paints that I purchased back in 2007 with no problems what so ever.
I purchased a can of the "basecoat" reducer and add the required amount to the Zero paints to get the correct viscosity for airbrushing.
The paints are extremely durable and have a long shelf life especially since Steve went to the glass bottles with the plastic lid under the metal cap.
I keep my Zero paints stored in a cool dark metal cabinet and the Zero catalyst for the 2K clears in my refrigerator so that they do not harden prematurely.
Cheers
John
The Following User Says Thank You to John18d For This Useful Post:
