Old 12-30-2015, 10:16 AM
miketo miketo is offline
flickering headlights,dash lights
05 gmc jimmy head and dash lights flickering, battery is about 3 years old and the altinator new this summer. the flicker is quite rapid.
Old 12-30-2015, 11:02 AM
aleekat aleekat is offline
Re: flickering headlights,dash lights
I would be looking at bad battery cables, grounds, dirty, corroded, not tight, etc..
Post back, that's what makes Forums Work.
The Following User Says Thank You to aleekat For This Useful Post:
miketo (12-30-2015)
Old 12-31-2015, 07:13 AM
Blue Bowtie's Avatar
Registered Offender
Good advice. Also check the alternator connections, including grounding through the mounting bracket.
I am going to wager that the flickering only occurs while the engine is running, and at about a 30 Hz. rate. It you're not looking closely you might not even notice the flickering. Is that correct?
I have seen this in a couple of instances, and using an analog voltmeter the voltage fluctuation can actually be observed. There is a chance that the alternator regulator is in oscillation which can be caused by poor connection of the E terminal, field terminals, or a failing rectifier in the alternator bridge. There is also a chance that the alternator brushes and slip rings are sticking or not seating well.
Old 12-31-2015, 10:05 AM
thanks guys, apart from the battery and alternator, where else should I look for grounding.
Old 01-16-2016, 02:50 PM
old_master's Avatar
Advisor/Moderator
If you haven't found the problem yet, there is a GM TSB that addresses this issue and takes care of the problem. Very easy fix and cost is under $10. A few posts down in this link, is a copy of the TSB:
http://chevyavalanchefanclub.com/caf...=131131.0;wap2 Connecting the new voltage sense wire to the underhood fuse panel, instead of the rear of the alternator, will give far better results, and brighter headlights
I would suggest a boneyard for the alternator connector, they usually only charge a couple of bucks for it.
You have to know how it works,
to figure out why it doesn't.
