Go Back   Automotive Forums Car Chat > Honda > General Discussion
Old 12-30-2015, 01:08 AM
emmaolivia emmaolivia is offline
Does my Acura need oil system flushing?
Hi
I have purchase a new Acura car. I just want to confirm Acura also need the oil system flushing as like the other cars. Also if the any problems comes to my car should i take it to the service center or car wholesalers and dealers?
Old 12-30-2015, 01:46 PM
MikeCStig MikeCStig is offline
Re: Does my Acura need oil system flushing?
Oil system flushing is never a bad idea, but to find out if it's necessary, you'll need to post more info about your car. What model? What year? How many miles on it? Any idea how well maintained it was, when it's last oil change was?
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 05-22-2017, 06:26 PM
Dale85 Dale85 is offline
Yes, oil flushing is helpful to get rid of the gunk out of your engine. You can then have an oil change and mix it up with an oil additive to maximise your engine oil. I am using the Valvoline Syntec, alongside the moly-graphene based Everglide as my oil additive. Graphene is very good for older cars, so this combination works perfectly for my 98 Acura. Let us know how it goes!
