Go Back   Automotive Forums Car Chat > Mazda > 6
Old 12-27-2015, 08:28 PM
teegolf teegolf is offline
Air bag/ SRS light stays on
2005 Mazda 6S with 122k for miles. The airbag SRS light on the dash is on all the time after I found the the pretensioner wire unplugged on drivers side and plugged it in. Light flashes the code of 33 which is related to the drivers side pretensioner. If I unplug the wire at the pretensioner the light will go out. Checked connections and such. Even went so far as to switch the driver and passenger seat belt tensioners around. Light stayed out until I plugged in the drivers side wire to tensioner using the passenger side tensioner. Tensioner from drivers side did not cause any codes when installed on the passenger side. Based I findings I assume tensioner is OK. Questioning the wires or the SAS module in the center console. Any body have a wiring diagram so I know where the wires terminate at the SAS to allow for testing or have any experience with this issue?
Thanks!
