Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 12-26-2015, 09:59 AM
Arkeith Arkeith is offline
Abs fuse location
2001 oldsmobile silhouette. I have a problem with my breaks vibrating. I was advised to pull the abs fuse to see if that solves my issue. I'm trying to pull the fuse, but I'm not 100% sure which fuse it is. Can anyone help me find the fuse?
I found 2 possible locations in the manual.
Fuse 5 and fuse 7.
The fuses and their description are below. I'm worried that if I pull one or both, they might remove power from other functions like my auto locks and power mirror
Fuse 5 - IGN MAIN 1
Ignition Switch to Fuses (Instrument Panel): ABS/TCS IGN, CRUISE, DRL, ELEC PRNDL, IGN 1, PSD, SIR, T/SIG and PCM [IGN MAIN Relay (Underhood Electrical Center Fuses: A/C CLU, ELEK IGN, IGN 1-U/H, INJ, TCC)]
Fuse 7 - BATT MAIN 1
Fuses (Instrument Panel): ABS MOD BATT, CIGAR/DLC, CTSY LAMP, FRT PWR SCKT, PWR LOCK, PWR MIRROR and RR PWR SCKT
I'm uploading a screenshot of the manual page. Any help would be appreciated.
Thanks
UPDATE: I went ahead and pulled both fuses (one at a time). Just as I feared, they stopped my remote starter/locks from working. Does anyone have an idea where the fuse is located? I don't really know anything about cars
Old 01-02-2016, 03:45 AM
sergeimoskva sergeimoskva is offline
Re: Abs fuse location
Hi !
Open the hatch on the passenger side. There is a fuse box.
On the inside of the hatch there is a picture Fuse.
(see picture)
The Following User Says Thank You to sergeimoskva For This Useful Post:
Arkeith (01-06-2016)
Old 01-04-2016, 09:42 PM
Tech II Tech II is offline
You can't pull the ABS/PCM fuse...vehicle might not start......
Sure you don't have a pulsation?
The Following User Says Thank You to Tech II For This Useful Post:
Old 01-06-2016, 02:49 AM
Tech II
Yes . You're right . The voltage on the control unit also turns off
On the reverse side of the hatch more fuses are indicated that relate to the ABS. I just can not remember - what.
Arkeith
Here is a diagram of the module ABS Delphi DBC-7
Depending on the model year of the car - the difference in the colors of the wires
Old 01-06-2016, 05:07 AM
Originally Posted by sergeimoskva View Post
Tech II
Arkeith
Perhaps you have a different arrangement of fuses
(see picture)
Old 01-06-2016, 09:26 PM
Thank you all for the responses!! I will check out the solutions this weekend
