Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 12-24-2015, 01:29 AM
syl153 syl153 is offline
1996 Olds Silhouette temp gauge
96 silhouette - temp gauge is showing 250 degrees. new radiator, new thermostat and new coolant sensor. water pump is circulating coolant. infrared temp on engine, hoses, etc. shows 192 or so degrees. heater is putting out lots of heat. low speed fan does not come on. high speed fan comes on when AC is turned on. any ideas on why the temp gauge is reading so high?
Old 12-24-2015, 10:14 AM
DeltaP DeltaP is offline
Re: 1996 Olds Silhouette temp gauge
Assuming the cooling system has been bled out properly. Does the hi fan running,( w/ A/C on), lower the gauge reading? Check fan speed relays,wiring,etc.
Old 12-24-2015, 12:32 PM
I found the relay box under the hood, but none of the relays are marked as to what they control. Is there a diagram of the relays and what they control and how to test them?
Old 12-24-2015, 01:49 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Please answer the inquiry about the system being bled. If it is not properly bled it will cause air pockets which will cause overheating issues.
Tags
1996 , gauge , silhouette , tempature
