Go Back   Automotive Forums Car Chat > Ford > Probe
Old 12-22-2015, 11:35 PM
Zschacht10 Zschacht10 is offline
Help
Ok so I'm my fuel pump won't kick on butnif I jump from diagnostic box it cuts on try to start while doing this and won't start I was told it may be a fuel pump relay. Any thoughts . second can a multi purpose relay be used in place of the fuel pump relay any help would be appreciated
Old 12-23-2015, 09:27 AM
MikeCStig MikeCStig is offline
Re: Help
You'll need to be more specific...
First you didn't put up enough info about your car, it's under the category "probe" so I'll take a wild guess that the question is about a Ford probe. What year? All Ford probes had issues, that's why they stopped making them, but each generation had different issues, so you'll have to give more info to get more answers.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 12-23-2015, 09:41 AM
Re: Help
It's a 95 Ford prob gt with a 2.5 and its not th inertia switch
