Old 12-18-2015, 02:29 PM
PleaseHelpMeh PleaseHelpMeh is offline
Help with choosing an amp
Hi, I've gotten my car, a 1995 Honda Civic, fairly recently and am trying to upgrade my sound system. So far I've bought and installed a Pioneer MVH-X380BT Media Player, and two pairs of Kicker CS65s. I bought one Kicker - CompR 12" Dual-Voice-Coil 2-Ohm Subwoofer which has an RMS of 500W. I completely neglected the fact that I need an amplifier for it though. This website (http://knowledge.sonicelectronix.com...-an-amplifier/) led me to believe that I'll need an amp that has an RMS of 500W at 4 Ohms. Is this true, and do you have any suggestions for what amp to get (preferably less than $150, but up to $200 at the most)?
Also, the dude at Best Buy suggested a ported box and I plan to build my own, and suggestions or advice on that?
Old 12-22-2015, 06:13 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Help with choosing an amp
a dual 2 ohm sub can be wired as a 1 ohm or 4 ohm load, a 500 watt amp rated at 1 ohm will typically be less expensive than one rated at 4 ohms.
Old 12-22-2015, 10:34 AM
I saw that, but was kinda confused. To wire it with 1 ohm wouldn't it need to be in parallel? How do I wire a single woofer in parallel? Thank you for your reply
Old 12-23-2015, 06:15 AM
Audio Guy
it's a single sub but is has 2 voice coils. Wiring both +'s together and both -'s together will put it in parallel. If you check it with a multimeter, it should read about .7 ohms
Tags
amp , choose , clueless , subwoofer
