Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 12-17-2015, 08:00 AM
tonysilva530 tonysilva530 is offline
My 500 dollar jetta
Actually bought it for my daughter......
It has the vr6......got it so cheap because the previous owner couldn't afford to have it repaired. It had a rattling timing chain and a leaky coolant pipe:
Got it home and took it apart:
Found the leaky coolant pipe (black) and replaced it with a better one (grey):
Found the broken timing chain guide and replaced it with a new one:
Removed the oil pan to check for smaller broken pieces (yes I found some):
Cleaned up the oil pan:
Cleaned the inside of the oil pan as well:
Got the engine reassembled:
Put the rest of the car together. Paid $500 for the car when it was broken.....it has 105k miles. kbb.com says it's estimated value in excellent condition is $4,500
Here's some pics of the interior (both seats are power, car has a sun roof, the rear window has a curtain, the a/c is the automatic climate control version, door panels have leather on them like the seats, the interior color is a light color.......not common options on most Jettas.....infact, I've never even seen another Jetta with the rear window curtain).
Old 12-17-2015, 08:38 PM
MikeCStig MikeCStig is offline
Re: My 500 dollar jetta
Now that's a hell of a score. I've always wanted a jetta vr6 but I was never able to find one in my price range... now I'm jealous, I would have been perfectly fine with doing the work you did. Hell, I bought a '91 Honda Prelude Si (almost 10 years ago) it needed a full engine rebuild which I did with performance parts, and in the end I was $2200 into a car worth about $5000 at the time. I thought I got a steal!
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
