Old 12-16-2015, 01:05 PM
Benjpatt Benjpatt is offline
cold chevy s10
This is the scenario:
  • 2000 Chevy s10
  • The cold air works great however the heat doesn't seem to work at all
  • The defrost works but only cold air comes out even if I have the blend door on full heat.
Can anyone tell me what the possibilities are. I couldn't find the blend door on the passenger side, I've checked the hoses and they seem fine, except for the following pic Could this have to do with the loss of heat?
Old 12-16-2015, 03:30 PM
brcidd's Avatar
brcidd brcidd is offline
Re: cold chevy s10
Hoses seem fine? Please elaborate- both need to be too hot to hold.
Does your truck have a water shut off/bypass valve on heater hoses? This could be stuck shut.
Other than that, number one cause of "no heat" is loss of coolant- is there plenty in your radiator? No just checking the burp box-need to know if radiator is full.
Temp door inside is the last place to look- only if both hoses are hot.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 12-17-2015, 08:35 PM
Re: cold chevy s10
How do i check the hoses to see if too hot to hold, i imagine the truck must be on and the a/c on as well
I don't know if there is a bypass/off valve on the heater hoses, what should they look like
I didn't know the radiator could be empty, i just assumed that because the burp box as you call it is full the radiator is full as well.
there is one other thing, there is a strange smell in the cab sometime, smells a little sweet and like something else but cant pin point it. however there is a film on the inner windshield and i wipe it and a couple days its back. could this be part of the problem and what should i do. Thank you for communicating with me on this.
Old 12-17-2015, 10:41 PM
aleekat aleekat is online now
Re: cold chevy s10
Leaking heater core or hose connection on the firewall.
[quote=there is one other thing, there is a strange smell in the cab sometime, smells a little sweet and like something else but cant pin point it. however there is a film on the inner windshield and i wipe it and a couple days its back. could this be part of the problem and what should i do. Thank you for communicating with me on this.
__________________[/QUOTE]
Post back, that's what makes Forums Work.
Old 12-19-2015, 07:16 AM
rhandwor rhandwor is offline
Re: cold chevy s10
I think you have a leaking heater core.
Old 12-19-2015, 08:15 PM
Re: cold chevy s10
Okay, Is there any particular way i should see or check this and where
Old 12-20-2015, 05:55 AM
Re: cold chevy s10
Their is a rubber drain tube the air conditioning systems drains condensate. The heater core is located next to the evaporator. If you have jack stands locate this hose. Place a big piece of cardboard under the firewall and passenger seat. Available free at a furniture store. Anti freeze leaves deposits depending on what type you use.
A hose fitting will be close to the firewall use a flashlight and look.
