Old 12-07-2015, 11:24 AM
Buffalo186 Buffalo186 is offline
Finishing PE
One thing I don't see discussed here much is how to finish PE parts. I struggle a lot with this. I've tried using keys, steelwool, self-etching primer and nothing seems to work. I get the final finish on the part and if I even look at it sideways a big chip falls off and exposes the raw alum or SS or whatever material it happens to be.
So I thought I'd ask and see what process you guys use to finish PE parts.
Have at it!
Old 12-07-2015, 08:45 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Finishing PE
Can you give some details as to the kinds of pe parts you've had trouble with? There are different techniques I use for different situations. As you've noticed, pe can be terrificly difficult to paint (or keep painted)- it suffers from being both metal and flexible. But some techniques may work better in certain situations than others.
PHOTOBUCKET SUCKS
Old 12-07-2015, 08:51 PM
mchernecki mchernecki is offline
Re: Finishing PE
What you need is some Etching Primer to bite into the metal. Try this one http://www.hobbyworld-usa.com/Store/...in-120ml-.html
Old 12-08-2015, 10:33 AM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
Re: Finishing PE
i use mr hobby metal primer (ex: https://www.eltallerdelmodelista.com...ml?language=en). i have not experienced chipping with it so far, even after applying it on a panel line template set which i regularly bend (i use it mainly on aircraft kits).
olly olly oxen free
