Old 12-04-2015, 09:27 PM
jsanroman1997 jsanroman1997 is offline
Exclamation Squeaking noise
I have a 1998 F-150 and I have a squeaking noise and I can only hear it when I am in in first gear at low speed and when I'm in reverse backing up and goes away when I press the clutch pedal. I'm thinking its either my U-Joints or Throwout bearing. Any ideas on what it could be?
Old 12-06-2015, 01:32 PM
65comet's Avatar
65comet 65comet is offline
Re: Squeaking noise
My guess is the exhaust heat shield by the catalytic converter. They can break loose and only make noise when in slow speed driving conditions.
Old 12-06-2015, 01:40 PM
Re: Squeaking noise
And I forgot to mention this in the question/problem but the squeak goes along with the wheel speed.
Old 12-07-2015, 01:03 AM
MikeCStig MikeCStig is offline
Re: Squeaking noise
I think you may be onto something with the throwout bearing idea. Also maybe your clutch disc is worn and its slipping just a little bit. Not enough to be noticeable through the power output, but just enough to make a little bit of noise.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
