Old 12-01-2015, 08:39 AM
Thepaperboy Thepaperboy is offline
Weird grinding when braking
So whenever I brake while reversing (and rarely while moving forwards) I hear this odd grinding noise coming from the front left wheel and can feel it through the brake. Im not a petrol head but I decided to replace a wheel bearing hub myself recently to save money. Im pretty sure I reconnected the anti lock brakes correctly though I doubt it's that. Any suggestion as to what it could be? (As for the obvious. Yes my brakes are good)
Old 12-01-2015, 11:02 AM
brcidd's Avatar
brcidd brcidd is offline
Re: Weird grinding when braking
Jack it up and turn wheel slowly- chances are good the splash shield is bent into rotor- needs clearance to spin freely-
or you may have a brake squealer letting you know you have worn out pads- since it only does it with brakes applied.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 12-01-2015, 02:54 PM
maxwedge maxwedge is offline
A990 racer
. Agreed, no quick diagnosis here.
Old 12-01-2015, 05:36 PM
I did notice that the shield was slightly bent when I replaced the wheel bearing hub. It's rusted to hell though so I wonder I I can't just take it off for good.
Old 12-02-2015, 10:51 AM
DeltaP DeltaP is offline
Inspect the shield for signs of contact,scraping with the rotor.Check for looseness. It can be bent back into shape if necessary to get clearance from rotor. Unless its rusted through and the metal is weak I'd leave it alone. The shield is extremely necessary to keep excess water,snow and debris clear of the spinning rotor,brake caliper and ABS tone ring. Do not eliminate it.
