Old 11-29-2015, 05:54 PM
ronrh21377 ronrh21377 is offline
Unhappy 1998 ohv overheating
1998 ford taurus ohv is overheating and coolant is leaking out of fill cap takes forever for the temp gauge to read anything then after 6 or 7 minutes of driving it shoots up to about midway overheats and can hear serp belt squeeling from getting wet from coolant
Re: 1998 ohv overheating
i am pretty sure that its a blown head gasket it seems to run good though!!??
Old 11-29-2015, 08:20 PM
seems as if the small hose on top of fill bottle going to engine top is clogged?
Old 11-29-2015, 10:26 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
It would certainly be nice if the issue is that simple. However, a plug in that hose would not explain the coolant temperature would seem to climb rapidly after 6 or 7 minutes of driving. Still though, it would be worth checking that hose.
-Rod
The Following User Says Thank You to shorod For This Useful Post:
ronrh21377 (11-30-2015)
Old 11-30-2015, 09:56 PM
Thumbs up Re: 1998 ohv overheating
also i seem to have alot of steam coming out of tailpipe and my coolant bottle smells like exhaust or gas??is there a quick easy way to check head gaskets????
Old 12-01-2015, 02:37 AM
brcidd's Avatar
brcidd brcidd is offline
I put a bread sack over top of radiator where cap screws on- does it blow up in 30 seconds? if so smell it- is it exhaust?
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 12-01-2015, 06:46 AM
shorod's Avatar
SHO No Mo
There are also combustion gas detectors that are around $30 and will confirm if you are getting combustion products in your cooling system.
You can also pull your spark plugs and check each plug for signs of burning coolant. The plug may be just really clean or it may even have a coolant discoloration if the leak is bad enough.
-Rod
