Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-28-2015, 07:59 PM
Promskpr65 Promskpr65 is offline
Issue with Water Pump replacement
2002 Dodge Ram 1500 4.7 liter. I replaced the water pump as well as the fan clutch. After I put everything back together I let the engine run for about 20 minutes and everything sounded fine. When I took the truck for a drive the fan sounds like its in a hurricane. Any suggestions? Could I have accidently put the fan backwards?
Old 11-29-2015, 09:24 AM
brcidd's Avatar
brcidd brcidd is offline
Re: Issue with Water Pump replacement
New fan clutch either has "morning sickness" or is locked up.
I usually describe it as it sounds like a jet engine.
Fan clutches re-act to radiator temperature and should only engage the fan when they feel the heat. Yours is engaging with or without heat. There is a chance it will break loose and start working okay after a 100 miles or so- or you can take it back and try again, or buy a better quality fan clutch.
This why I despise fan clutches- at least with an electric fan, you know if it is working properly.
Better to have it fail this way, than the opposite, not spinning at all.
Fan blades are usually unable to be installed backwards..Which way is air blowing? Does a tissue cling to front of condenser? or blow off?
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
The Following User Says Thank You to brcidd For This Useful Post:
Promskpr65 (11-29-2015)
Old 11-29-2015, 11:51 AM
Thanks for the reply. You are right about the sound sounding more like a jet engine. I will replace the clutch with a better quality. Question though, since the fan clutch is attached to the water pump, is there any chance that the water pump could be the issue?
Old 11-29-2015, 07:06 PM
I replaced the fan clutch with another new one and I had the same issue. I burped the system by raising the right front and let it idle for about 45 minutes with the heater on full. I drove th truck for 15 minutes or so and the clutch finally engaged and the sound went away. Maybe the cold temperature contributed with the clutch's delayed cooperation.
Thanks again for your expertise.
Old 11-30-2015, 09:20 AM
brcidd's Avatar
Good to know it let loose--
BTW- you drove it and the fan clutch disengaged- not engaged-- it engages when hot and makes the jet engine noise, when free- wheeling, all is quiet....
'99 GMC Yukon
Promskpr65 (11-30-2015)
Old 11-30-2015, 11:00 AM
DeltaP DeltaP is offline
I've found some aftermarket brands to be louder than others but were working/cycling ok.
The Following User Says Thank You to DeltaP For This Useful Post:
