Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-24-2015, 10:32 PM
RamRiderSteve RamRiderSteve is offline
Oil Leak 2011 Hemi
Noticed a small oil leak that seemed to be getting worse. Appeared to leak from the oil filter.
Took it in for an oil & filter change. The next morning, I noticed a spot of clean oil on the garage floor.
Since she has a new filter, it is unlikely that the filter is leaking. She has 29,000 miles and synthetic oil.
If it isn't the oil filter, what above the filter could be leaking?
Thanks for your help.
Old 11-25-2015, 06:17 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Oil Leak 2011 Hemi
I have the best luck finding leaks by looking at night with a good flashlight...no daytime light interfering.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 11-27-2015, 05:09 PM
As fate would have it, the leak may have been fixed when the oil/filter were changed.
After inspecting, wiping and driving, i put fresh paper under the truck & voila, no leak so far.
Thanks for the help.
Old 11-27-2015, 05:42 PM
AF - Advisor
You know the oil pan is made of plastic so the drain plug torque is very important...don't want to overtighten and possibly damage the threads. The torque is 25 ft lbs.
