Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 11-21-2015, 12:30 PM
Sglout Sglout is offline
Is the rust on this car too much
Hello
I'm considering importing a Toyota Land Cruiser Prado (Lexus GX) from Japan. The car was manufactured in December 2013 and mileage is only 100 kms. Everything is good about the car, except the fact that it has a little rust under the body due to sitting idle for almost 2 years. I would like to know if the rust is bad enough for me to not buy this car or a little paint would eliminate the problem? Would really appreciate your input. Please look at the attached pictures. Thanks in advance.
Old 11-22-2015, 10:16 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Is the rust on this car too much
That seems for the most part to be surface rust and not a problem. It's hard to be sure on the small amount of chassis rust.
Not that I'm a perfectionist, but I'd use it as a bargaining chip and see if you can get the price down a little. Doesn't look bad to me.
One thing you can do is check is see if this vehicle (in American trim) has any recalls of consequence. There are a few Toyota trucks with chassis rust recalls.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
The Following User Says Thank You to Brian R. For This Useful Post:
Sglout (11-22-2015)
Old 11-22-2015, 10:25 PM
Thanks Brian.. I think I'll go ahead and buy the car.. It seems that it's not really a big deal.. Let's hope everything works out..
Old 11-23-2015, 11:09 AM
Brian R.'s Avatar
Resident Chemist
I didn't mention it in the previous post, but what I'd look for are damage to the undercarriage like deep gouges which may not be serious from a functional point of view, but would indicate the vehicle had been taken off-road and need suspension work.
Old 11-23-2015, 06:09 PM
MikeCStig MikeCStig is offline
The only areas I saw that concerned me slightly were around the cv joints. Just because the rust on the shafts themselves makes me thinks of the boots getting dry and cracking. If those boots don't stay sealed, dirt and crud gets into the cv joints and ruins the spider gears inside pretty quickly. Trust me, it's a pain in the ass.
Rust is kind of like cancer for cars. You want to catch it early and get rid of it before it spreads and affects vital parts of your car. Like in your case; cv joints and suspension and steering components. Yours really isn't that serious, just clean it up before it becomes a problem and you'll be fine.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Tags
cruiser , gx470 , land , rust , toyota
