Old 11-08-2015, 10:39 AM
Nosfer's Avatar
Nosfer Nosfer is offline
Volkswagen Golf 3 Variant (#USCP)
Hello friends!
I begin to do Golf 3 variant. I hope you will be interested
The basis will be taken this KIT from fujimi:
want to have something like this:
Let's start!
Firm gives the GTI version of the Golf.
Variant will be in stock.
To do this, first remove the plastic fender from the body and skirts from bumpers.
Result:
Old 11-08-2015, 06:36 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Re: Volkswagen Golf 3 Variant (#USCP)
Great start will be watching this.
In Progress
Old 11-08-2015, 09:22 PM
sbvwfanatic sbvwfanatic is offline
Oh I'm watching this one. Can't wait.
The Following User Says Thank You to sbvwfanatic For This Useful Post:
Nosfer (11-09-2015)
Old 11-12-2015, 05:05 AM
Nosfer's Avatar
Today I made side moldings.
Fujimi KIT has GTI moldings:
On Variant they must be not so wide and closer to wheel archs:
DONE:
I also completed the correct form of front skirt:
DONE:
Old 11-14-2015, 01:44 AM
ChristopheB's Avatar
ChristopheB ChristopheB is offline
Interesting WIP, thanks for sharing!
Christophe.
The Following User Says Thank You to ChristopheB For This Useful Post:
Nosfer (11-14-2015)
Old 11-17-2015, 09:57 PM
MidMazar's Avatar
Looking good. But if you plan on resin casting this one is there a big market for it? A three door GTI wouldn't have better sales when casted? Either way your progress looks really good. Mouldings and bumper look spot on. I wish someone made a detailed VR6 engine set. Hint Hint
In Progress
Old 11-25-2015, 04:52 AM
Nosfer's Avatar
Here we are getting to the fun part - the geometry of the rear part! Back of body I will do from the bumper - from it is easier to make the right proportions. To begin, I cut a notch in it under the back door. KIT bumper is flat:
In our own prototype rear door drops lower than hatchback:
on this picture I saw where the recess begins at the door - at the level of "slightly below the middle of the rack," if you look strictly at the back:
Cut:
Then it is necessary to extend the bumper. Cars have the same base and the difference in the length of the body is obtained just by the rear overhang. In scale the rear overhang of wagon must be 28mm. I make the mark on the bumper to extending:
Need to add a 9mm
"Missing" body parts, I'll cut from the same body that I have.
In this case, a piece of the rear bumper:
Done:
Cut the back door:
Now for the back door. We wagon tailgate window has a different shape. Rear rack should be more vertical. Rear window should be 29mm long. On the picture I mentioned these points:
"missed" almost 2mm. I cut the rack together with the factory panel lines and just put it there where it is necessary
In the crack paste a piece from another body
Done!
That's all for today.
Stay tuned
Old 11-25-2015, 06:43 AM
RoMaNo93's Avatar
RoMaNo93 RoMaNo93 is offline
Superb Work, suscribed for sure...
if my English is bad...Spanishman
Aus Liebe Zum Auto...Volkswagen: wirklich, alte Schule
The Following User Says Thank You to RoMaNo93 For This Useful Post:
Nosfer (11-27-2015)
Old 11-26-2015, 12:42 PM
koooba's Avatar
koooba koooba is offline
I find this project very interesting and will follow your progress for sure!
The Following User Says Thank You to koooba For This Useful Post:
Nosfer (11-27-2015)
Old 12-01-2015, 12:38 PM
Nosfer's Avatar
Today I'll show you changes in the back.
It will be a lot of photos and little comments
The handle of the back door:
Replace the back part:
It remains only to complete the missing parts
Old 12-01-2015, 12:40 PM
BVC500 BVC500 is offline
Wow! Major surgery and it's looking good.
Old 12-02-2015, 12:00 AM
MidMazar's Avatar
Overall it seems like there isn't as many comments in general not just in your build. Don't get discouraged, your progress is topnotch!! It could also be as its not a popular car here in the states, as I would rarely see them. If I did, a older mom would be driving it. The rear is coming out really good. I really like how you made the handle. Don't worry many people are watching but not posting.
What putty do you use on the taillights? Two part epoxy?
In Progress
Old 12-02-2015, 02:59 AM
Nosfer's Avatar
Thak you!) That putty is Tamiya Light Cutting Putty.
Great stuff! It makes work much quicker
Old 12-09-2015, 07:08 AM
Nosfer's Avatar
continue ...
Finish body side. Parts taken from the "donor" Body
...on the other side:
Fuel tank flap I cut from old shells:
Next, I added the length of the roof.I use a piece of a "donor":
In order not to distort the geometry while I am engaged in the uprights, I put temporary stiffeners
It can be seen that the roof is too low in the rear
The shape of the roof at the wagon differs from a hatchback since the central pillar.
On Facebook one person warned me about it (thanks to him for care).
The solution - the rear pillar is extended by 1 mm. The roof stood as it should:
Old 12-09-2015, 11:08 AM
mrceej mrceej is offline
Good work, keep it up!
