Go Back   Automotive Forums Car Chat > GMC > Savana
Old 11-06-2015, 09:28 PM
sky501 sky501 is offline
96 GMC SAVANA 4L60-E trans-drain converter
how can I drain (flush) the converter without removing it
Old 11-07-2015, 01:29 PM
maxwedge maxwedge is offline
A990 racer
Re: 96 GMC SAVANA 4L60-E trans-drain converter
Cannot, you could disconnect a cooler line at the rad. then run say 10 qts thru the trans to flush the conv. and trans, use the cooler in line at the rad. to do this and a way to catch the old fluid.
Old 11-08-2015, 12:23 PM
Thumbs up Re: 96 GMC SAVANA 4L60-E trans-drain converter
That was pretty much what I figured-------was just checking to see if maybe someone knew of a "magic bullet", since GM no longer puts a drain plug on them!!!!
