How do you remove the mirror glass from a 2014/2015 Honda Accord side mirror??
Re: Techs!!! Need Help With Mirror
From what I've seen in Civic manuals is you move the top of mirror glass all the way forward, then reach in behind mirror with flat blade from below to pop glass away from it's holder. Like a ball and socket type mounting.
New glass pops into place. |
Follow Up for those in the future that have the same issue.
Remove the mirror assembly and take it to a workbench. Move the bottom of the glass out as far as you can get it. Use a wood paint stirring stick and pull the bottom of the mirror glass out some. At the 5 O'Clock and 7 O'Clock positions there are slots that will accept a long shaft small flat blade screw driver. Guide the blade into the slot and twist. You'll need to start in one corner with the glass pulled out with the stick, then slide the stick to the other side and get the blade into the slot and twist. This should unlock the bottom of the mirror glass from the movable motor plate. Lift the mirror glass up from the bottom and off and disconnect the wire leads for the defrost feature. Now you can get at three tabs along the top and two screws on the right to remove the front piece of the shell. Remove the screws around the motor base to release the back of the shell. |
