Go Back   Automotive Forums Car Chat > Ford > Club Wagon
Old 11-02-2015, 03:41 PM
PackMule PackMule is offline
Angry Cranks Won't Start / Run. ( Somewhere a R.K.S.?)
My '85 Club Wagon Must have a "REMOTE KILL SWITCH, device!" I can't find it! Could it be in the computer? Happens when I need the van the most!
Old 11-02-2015, 04:24 PM
aleekat aleekat is online now
Re: Cranks Won't Start / Run. ( Somewhere a R.K.S.?)
Need more details. Does it crank, crank, no start? Doesn't do anything? Dash lights dim out when trying?
Post back, that's what makes Forums Work.
Old 12-16-2015, 07:09 AM
rhandwor rhandwor is offline
The pickup in the distributor and the module are the main problems if the engine won't start or shuts down when running.
Old 12-16-2015, 09:23 AM
Unhappy Re: Cranks Won't Start / Run. ( Somewhere a R.K.S.?)
Well... Yesterday I put a Spark test LIGHT, between the Spark Plug Wire, And The Dis. Cap:[ No Light! when cranking over... SO: I put the light between the coil, and the Dis. Cap... [ LIGHT ] Took out the light put the wire back on & STARTED UP!!! CRAZY " Y E S !"
Old 12-16-2015, 06:07 PM
DeltaP DeltaP is offline
"The pickup in the distributor and the module are the main problems if the engine won't start or shuts down when running."
Agreed but it could be as simple as the rotor. Also I remember back in the day the Dura Spark module harness connector pins would corrode.
Old 12-16-2015, 08:36 PM
MikeCStig MikeCStig is offline
Distributor caps are generally pretty inexpensive, so replacing yours would be a good place to start. If that doesn't solve your problem, that's when you'll need to look at the coil, rotor, and even possibly the module. It's possible that you entire distributor is going bad.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 12-17-2015, 07:46 AM
Start by checking the computer ground close to computer. Use test light and check for voltage at coil positive. If this is good place test light on coil negative the light should blink when cranking. If it blinks and won't start replace module on side of distributor. Remember to mark rotor and base of distributor so you can reinstall. If it don't blink replace the PIP.
A deep 7/32 or 5.5mm socket fits the nuts. KD makes a small tool.
If no power to the coil replace the relay for the computer.
As both the PIP or Module will heat up and quit working you need to check when it won't start.
I have a module tester and they check good. I then put a drop of water on the metal plate and heater with a blow dryer and quit as soon as I observe a bubble. Many quit working when hot and start working when cool. It takes a tool to replace the PIP purchase a junk yard or rebuilt if the PIP is bad. Replace the distributor cap if corroded or no vent.
