Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-29-2015, 07:19 PM
duh101 duh101 is offline
2003 Ram 2500, clunking in front end.
Today, I installed a 2.5 inch leveling kit on the truck. Now when I go over a bump, I hear a "clunk" as if something is dropping down onto another component in the front end. Sway bar links are good. Springs and strut assembly are tightened down well. Could it just be the spring on the new shocks and spacers, or do I need to check other components? Thanks!
Old 10-29-2015, 08:01 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 2003 Ram 2500, clunking in front end.
I don't know, I lowered the rear on mine to level it.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 10-29-2015, 08:15 PM
I've heard to check the track bar and also the top of the strut assemblies to ensure tightness. Anything else to look for?
Old 10-30-2015, 09:00 PM
AF - Advisor
You could jack up the front, let it down slow and watch & listen for anything odd
Old 10-31-2015, 12:59 PM
Update: No more clunking. The bottom bolt of the right shock somehow came out, causing it to hit the metal there. Put a bolt in, tightened with impact and voila, no noise!
