Old 10-26-2015, 10:16 PM
Nora.Tursso Nora.Tursso is offline
P1811
2001 chevy lumina, 225,000 miles but sat in barn 6 years. Perfect car. Runs so well. I have taken excellent care of car. It runs so well.
Already had solenoid changed b4, but never transmission replaced. Car is old. Do I just get a different car at this point? P1811 is there again.
I brought car for minor repair and high pressure engine cleaning. Radiator hose got knocked off and major over heating until back in garage next day. Could that have triggered something though unlikely.
Hopeless in Minnesota
Old 10-27-2015, 08:26 AM
Schurkey Schurkey is offline
Re: P1811
Why did you start two threads on exactly the same topic?
http://www.automotiveforums.com/vbul....php?t=1144409
How about we reply in the other thread, and let this one die? Or perhaps a moderator can remove it altogether.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 10-27-2015, 08:51 AM
Re: P1811 code
http://www.automotiveforums.com/vbul....php?t=1144408
Find a service manual, follow the directions for that trouble code.
Thank you. Didnt know how to delete second posting. Im new here
Old 10-27-2015, 09:16 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: P1811 code
You probably have worn/damaged seals causing a low pressure issue. Depending on how attatched you are to the car, either replace the transmission or the car. Possible just a valve body cleaning or the solenoid is sticking, but with the miles, and the time sitting with no lubricants flowing through the trans, best to replace the trans...
Old 10-27-2015, 09:49 AM
Re: P1811 code
I was going to wait for 3 months to pass at new job and buy new car. The thing about this car is such excellent condition and runs so good. But your right. Thank you
Old 10-29-2015, 06:49 PM
Blue Bowtie's Avatar
Registered Offender
Re: P1811
If the condition is that good, it might warrant a trans swap. You'll have to crunch the numbers to see if it is worthwhile to you. You could probably replace it foe something newer and with lower mileage for what it might cost unless you perform the work yourself. Then again, as a trade it may also have some value.
Old 10-29-2015, 08:32 PM
Re: P1811
Thank you very much. Its starting to make sense. I had a oil leak and a garage did high power engine clean. Many other odd problems from that. Water may have went into seals that triggered the p1811. I'll give it a week then have it checked and serviced.
Why cant mechanics take responsibility instead of being hostile. Are they afraid of bosses? After the engine power cleaned i was strand because of radiator right after for 5 hours. Hose came loose. Headlights pulsing too and these readings. It was extremely stressed for a week.
Garage said none of it was from that. Lesson learned
