Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 10-22-2015, 10:09 PM
buickmastermind's Avatar
buickmastermind buickmastermind is offline
1993 SSEi twincharged 6MT
A few years back I picked this up for $400:
Many things happening later:
Many many many more things happened, eventually it was a running series 2 L67 powered rusto-resto:
Somewhere along the way I ended up with an NIC cam and 3.25 pulley build, using modified LG3 headers.
Then I got around to some body work:
And then I broke the input shaft on the 4t65e-HD. Decided it was time to upgrade..
As if that wasn't enough, I slapped on a custom turbo setup:
Eventually I got everything done, running, and took it out for some fun!
And what fun would it be without a track day?
https://youtu.be/Y2gkpAs7SDQ
Setup is limited to 9psi for the moment, fuel injector upgrade is on the way along with e85. Everything is ready for 25psi, just need fuel and a tune. There are several other mods in the works, some will go on this winter, others will be an ongoing project.
Some highlights:
Series 2 L67 M90 + Holset HY35: M90 power is bypassed once turbo spools
F40 6-speed manual
Driveshaftshop.com 800hp custom
C/V axles F-body front brakes
Rear disc brakes with vented rotors
Using the Buick GN double roller timing set
Custom made equal length primary headers
Intercooled turbo
Supplemental electric oil pump with bypass filter and oil cooler
working A/C
W-body KYB AGX struts
HID projector retrofits
1986 LeSabre Limited L67 sleeper
Fully ported & polished, shift kit, CAI, F41 polyurethane suspension, headers & 3" exhuast,
Old 10-23-2015, 11:28 AM
Tech II Tech II is offline
Re: 1993 SSEi twincharged 6MT
Holy crap! You must have a lot of time to spare......great job, though....
