Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 10-15-2015, 02:27 PM
AllGM AllGM is offline
2004 3.4L GM Deck Height
I think I may have a problem. Head gasket blew. When taking off the heads a noticed severe (deep) machining marks on the decks (probably there since engine was built) and some corrosion around a water passage. Took the engine to a local engine shop. He said he could take some off the top. I said ok. Now during reassembly the pistons stick out above the deck at TDC. is some protrusion as designed? Piston travels .025" above deck now.
Old 10-15-2015, 06:47 PM
maxwedge maxwedge is offline
A990 racer
Re: 2004 3.4L GM Deck Height
How much did he take off the deck, what is the stock deck height, machinist should have this info and acted accordingly!
Old 10-15-2015, 10:38 PM
He said just .006" was removed, and it is normal for the pistons on this engine to protrude from the top of the deck. True??
Old 10-16-2015, 08:37 PM
A990 racer
Don't have the blue print specs, but .006 shouldn't be an issue.
