Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 10-15-2015, 11:43 AM
curiousvi curiousvi is offline
Question I found this in oil pan...can you tell me what is it?
I finally took out oil pan and apart from some small metal shavings I found this big piece...
http://api.viglink.com/api/click?for...Dw1034-h775-no
I can not figure out what is it....can someone suggest?
Old 10-15-2015, 11:51 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: I found this in oil pan...can you tell me what is it?
it looks to be a wiped out rod or main bearing. was engine knocking before you took it apart. why did you take pan off?
Old 10-15-2015, 02:03 PM
I am not sure if it was knock but this was the sound before I took it apart..
https://www.youtube.com/watch?v=v6iu...ature=youtu.be
Also when I took it apart I also removed crankshaft journals and bearing (those half moon) and I dont see any damage..just the normal wear
I am yet to remove further parts from bottom end... also started taking head apart..did not reach the head bolts yet...neither have taken valve cover off..
Old 10-15-2015, 02:41 PM
Crvett69's Avatar
can't tell if noise was coming from up top or down below. did you take the main caps or the rod caps off?
Old 10-15-2015, 02:51 PM
I don't know the difference .... If you look from the bottom the first cap which has 2 12 mm bolts and once u remove that there is half moon shape bearing
Old 10-15-2015, 02:57 PM
Crvett69's Avatar
are 2 set of bearings down there, there are 2 on each conecting rod, they go up and down with the pistons as crank rotates. the main bearings are what hold the crank in the block, should have 2 or more bolts holding them on and will be about 5 of the main bearing caps. if you can take a picture of the one rod cap you pulled off, want to see what bearing looks like
Old 10-15-2015, 04:50 PM
Please check pic. ...all 4 of them are almost same..
Old 10-15-2015, 05:05 PM
Crvett69's Avatar
thats a connecting rod cap and bearing shell, will be another one on the top. now you need to pull the main bearing caps and check all of them. there is a lot of metal embedded in that bearing, block needs to be taken apart, tanked and rebuilt
