Go Back   Automotive Forums Car Chat > Dodge > Magnum | Magnum SRT8
Old 10-14-2015, 06:07 PM
gam101's Avatar
gam101 gam101 is offline
Send a message via ICQ to gam101 Send a message via AIM to gam101 Send a message via Yahoo to gam101
Exclamation Need help with Magnum 5.7 Hemi's OBD codes
Greetings folks!,
Posting here to get some input on my struggle with my 2007 Magnum SRT8 5.7 Hemi (the beast). Please help if you have any idea.
Following is the narrative of the Beast;
About 3 weeks are so ago I had all the sensors swapped on my beast (had other priority suspension & exhaust work), but for some reason she did not like that O2 sensor swap.
The O2 sensors were ordered from RockAuto & when I got them, all 4 sensors were not identical. 2 were same, however the other 2 were different. So total of 3 different brands of sensors.
Now, I am occasionally experiencing engine stutter on the 1st gear & then the engine light starts to blink. The quick solution I have found is to pull-over, turn off & restart the engine & then drive off. Although, this does not always work.
I got myself a wifi based OBD2 reader, downloaded DashCommand & Car Doctor apps on my phone to see what the codes (P0300, P0001, P0520, P0132, P0138) were & the attached are screenshots. I am going to post O2 voltage screenshots too from Car Doctor.
For now, please let me know if anything comes to mind on what could be the issue.
I don't want to run to the mechanic yet because I have a feeling he will just swap parts (ignition coils, injectors) out that may not resolve the underlying issue. I have already had the 16 plugs swapped too.
Thank you, again.
Old 01-16-2016, 08:06 AM
rhandwor rhandwor is offline
Re: Need help with Magnum 5.7 Hemi's OBD codes
A lot of O2 sensor codes are caused by air leaks and a catalytic converter plugging up. google for catalytic converter checking U-tube videos. http://www.rockauto.com/ Their converter company used to have a video on checking.
