Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 10-12-2015, 09:51 PM
coachcoffy coachcoffy is offline
85 Trans Am,won't accelerate,backfires,no power
I have an 85 T/A ,305 TPI, the motors been rebuilt,has 2000 miles on it,all sensors on motor are new,we've checked timing,it's exact,it starts,run a little rich and rough,but it smoothes out a little.you can drive it slow as long as you don't accelerate, You try to accelerate it cuts out,back fires. I've tested the ignition module & pick up coil,& as I said the knock sensor,map sensor are new, I'm at a stand still,all new plugs,wires,distributor cap & rotor,Please does anyone have any advice or ideas,
Old 10-13-2015, 05:05 PM
j cAT j cAT is offline
Re: 85 Trans Am,won't accelerate,backfires,no power
what is the back pressure ? I would open the exhaust up stream of the cat converter see if it runs better. what about the heat riser that open ?
fuel evap valves working properly these can suck extra fuel into the engine and melt down the converters.
EGR replaced the last 10 yrs ?
The Following User Says Thank You to j cAT For This Useful Post:
coachcoffy (10-13-2015)
Old 10-13-2015, 07:50 PM
[quote=j cAT;7173004]what is the back pressure ? I would open the exhaust up stream of the cat converter see if it runs better. what about the heat riser that open ?
EGR replaced the last 10 yrs ?[/QUOTE Thank you for your quick reply,EGR was replaced when we put the engine back in,2000 miles ago,my son put headers on it so I'm not sure about the heat riser,or the back pressure,I will go out and check it in a few minutes & check the cat converter,I forgot if we replaced it with everything else or not.I know all of the sensors & modules were replaced,& I just checked pick up coil & had ignition module checked,I really appreciate the info,also we didn't replace the electronic spark control module,could that be it,no way to test them that I know of, thanks again,I'll let you know results in a while.
Old 10-13-2015, 09:20 PM
O'k, I checked EGR valve,cat converter and evap valves,there aren't any.exhaust has headers into 2 1/2 pipe back to mufflers,EGR valve was taken out before engine rebuild,and I look for the evap canister & it was taken out also. The car was running good and then just started acting up.So I replaced,plugs,wires,rotopr cap & distributor cap,ignition module, & still doing the same thing,runs but no power and backfires on acceleration. I do thank you for your information,any other ideas are greatly apprecited
Old 10-14-2015, 05:07 PM
777stickman 777stickman is offline
I would be inclined to look at valve timing. Do a compression test on all holes. Check cam timing. Check valve adjustment.
Another issue could be a way too lean A/F ratio.
Good Luck.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
The Following User Says Thank You to 777stickman For This Useful Post:
coachcoffy (10-15-2015)
Old 10-14-2015, 05:55 PM
Good Luck.
Thank you for your information,I will check the valve adjustment and compression this evening & let you know. I'm not sure how to check valve & cam timing if its different than just checking the timing,I have checked the timimg,even tried it a little advanced. but one thing I didn't mention,the timing mark on the crank is kind of jumpy, it moves up & down 5-10 degrees at idle,I'll check the valves tonight,thanks again.
Old 10-14-2015, 06:54 PM
brcidd's Avatar
brcidd brcidd is offline
Backfires on acceleration-- is usually lack of fuel- or more commonly fuel pressure- have you tested fuel pump pressure?
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 10-15-2015, 09:09 AM
Yes actually,it's right at 40lbs which is what it calls for I think thats what it said,it's definitely running rich & backfiring,black smoke out both exhaust pipes ,& backfire when you accelerate, thank you for your info though,
Old 10-15-2015, 06:35 PM
to change the timing you need to disconnect the EST connector. this when disconnected removes all spark advance. then I think its 700 RPM you set the timing to like 7deg BTDC...
I still have a 1984 305 berlinetta.. timing if too retarded could do it..
another tool to use would be a vacuum gauge.. vacuum should be 17-21 inches and hold steady .. if the reading is jumping around that would be bad valves.. a bad valve will do it.. so then you do compression check compare all cylinders..
good luck..
Old 10-15-2015, 07:31 PM
good luck..
thank you, We're going to start on that tonight, I appreciate your help,thanks again, Mike
Old 10-18-2015, 10:39 AM
Blue Bowtie's Avatar
Registered Offender
Is it still running the stock (Bosch) injectors?
Old 10-19-2015, 10:56 AM
No we put new ones in when the motor was rebuilt,has 2000 miles on it,and fuel pressure is 40lbs,and it is blowing black smoke ideing,& backfires when accelerating,even in park,
Old 04-29-2016, 02:57 AM
Magnum01 Magnum01 is offline
If this problem persists, Or is even going on.. For what it's worth. The timing chain could've slipped.. It's one of those things no one really checks but it does happen. If the problems resolved then carry on.
Old 04-30-2016, 07:45 AM
Thank you,I thought about that,but really didn't want to face it,LOL,I kind of wonder if it's worth keeping it all original or switch motors to a newer one,this is the first year for TPI and I know why it didn't last.Any how thanks for the advice,I guess reality is I'm going to have to go that route.thanks
Old 05-01-2016, 08:25 AM
Registered Offender
What flow rate injectors were installed?
