Go Back   Automotive Forums Car Chat > Pontiac > Vibe > General Discussion
Old 10-08-2015, 11:48 AM
Bimmer50 Bimmer50 is offline
Pontiac Vibe 2003
My Vibe with 220k miles died on me one evening.Got it home and tore into 2 months ago and it still isn't running.To date I have :
New fuel pump
Valve job
Plugs
Injector seals
Timing Chain and Sprockets
VVT actuator
Timing chain tensioner
I haven't changed the fuel filter or done a fuel pressure check yet.
When I turn the key to ON nothing happens When I turn the key to start then release it the fuel pump runs for 2-3 seconds - actually backwards from what its supposed to do !!!
I read a similar post about a Toyota Corolla with the same problem but I didn't find answer. Somebody please help !!
Old 10-08-2015, 02:48 PM
Tech II Tech II is offline
Re: Pontiac Vibe 2003
While it says pontiac on the outside, it's really a Toyota on the inside......the Toyota version is called the Matrix.....think you will get a better response by posting in that column....
The Following User Says Thank You to Tech II For This Useful Post:
Bimmer50 (10-08-2015)
