Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 10-07-2015, 06:08 AM
scott bush scott bush is offline
Question Shocks
I have a71 convertible. It has air shocks on the back. One leaks down and I want to get rid of them. what is a good shock for this? It's not high performance, just a cruiser but don't what to get. what shocks keep the stance like the air shocks or is that the springs?
Old 04-27-2017, 09:17 AM
Ol'Jim Ol'Jim is offline
Re: Shocks
Hey Scott, I just saw your post, and it looks like nobody answered your question.
Did you end up replacing your air shocks? If so, what shocks did you put on instead?
Thanks.
-Jim
2015 Silverado Crew Cab 2500HD 6.6 Duramax 4x4
2002 Silverado Crewcab HD 2500 6.0 4x4 Sold 281K Great Truck
1970 Chevelle SS454 (Gave to my son 9 years ago for his 18th birthday. Yeah, I know, crazy, right? Thank goodness he doesn't drive it the way I would, -er, did...).
1971 Monte Carlo SS454 Drag Racer. The old girl finally got new paint!
1968 Camaro SS (New race car project). Caged, Tubbed, Back-Half/Ladder Bars. Rolling Chassis (For now).
Old 11-12-2017, 10:52 AM
rhandwor rhandwor is offline
Re: Shocks
Shocks won't help with the ride height. A couple new springs will correct this problem. Check the air line to the bad air shock this could be the problem.
Old 11-13-2017, 08:51 AM
Re: Shocks
I agree, although coil-over shocks with springs may provide a slightly higher stance. You can buy universal replacement air line/installation kits for most air shocks, usually they start leaking at one of the fittings. The plastic line gets hard and loses it's ability to seal. You can try removing the fittings one at a time, and using a sharp knife, try cutting a half-inch off the end of each air line, then reinstall the nuts. I would recommend a new line kit, they are cheap, and they usually include a "T" fitting, so you only have one place to add air, and it fills both shocks equally, and balances the pressure between them.
-Jim
