Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-06-2015, 09:15 PM
pooae pooae is offline
fluid capacity question
The local library doesn't have the manual anymore so I couldn't look it up.
For a 2000 6-cyl, 1MZ-FE Camry:
How much comes out when you drain the transmission fluid?
Doesn't the transmission and differential share fluid?
How much comes out when you drain the radiator?
How much does the entire cooling system hold?
How much does the power steering system hold? Does it use ATF?
Old 10-06-2015, 09:32 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: fluid capacity question
E-mail me and I can send you a manual
Diff and transmission have separate sumps.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 10-07-2015, 10:41 AM
somick's Avatar
somick somick is offline
For my 2004 LE, 4 cyl:
Transmission - drain/refill: 3.7 quarts;
Coolant - drain/refill: 1 gallon;
I believe you need 1 quart to drain/refill power steering .
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
