Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 10-05-2015, 08:42 AM
Greg Gore Greg Gore is offline
Montana or Silhouette Cluster w/ Tach Work in a Venture?
Anybody know if a 2001 to 2004 Montana or Silhouette instrument cluster will swap into a 2003 Venture in order to have a factory tachometer? Looks like the mounting tabs are the same and the electrical connectors appear to be the same. Will the Venture PCM support the tachometer and will the electrical connections be correct?
Reason I am asking is I believe I am about to get into stepper motor replacement on my Venture cluster anyway because the temperature gauge is now occasionally going to full scale and if I could get a Montana cluster and rebuild that instead it would be cool to have the tach.
Thanks in advance,
Greg G
Old 10-20-2015, 06:47 AM
sergeimoskva sergeimoskva is offline
Re: Montana or Silhouette Cluster w/ Tach Work in a Venture?
Hi!
Instrument cluster Pontiac Montana (2001-2004) and the instrument cluster Chevy Ventura (2001-2004) - are identical
The Following User Says Thank You to sergeimoskva For This Useful Post:
Greg Gore (10-20-2015)
Old 05-31-2016, 02:12 PM
Venture3400 Venture3400 is offline
Clusters will not interchange. Electrical plugs are different and possibly may be linked to the VIN numbern
The Following User Says Thank You to Venture3400 For This Useful Post:
Greg Gore (07-07-2016)
