Old 10-04-2015, 07:48 PM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
It's gotta be the starter...doesn't it?
On my last truck I knew the starter was going bad when it took longer and longer to start before it finally wouldn't start until I tapped on the starter, ultimately wouldn't start at all..
With this k1500, I never had the slow starts, it just wouldn't start one day. Tap of the starter and it finally started. Ran fine for a couple days, then again wouldn't start. Tap on starter, fired right up.
It's just odd that my 2 experiences were so different. Which one is more typical?
This ain't your grandma's car!!
Old 10-04-2015, 08:51 PM
brcidd's Avatar
brcidd brcidd is offline
Re: It's gotta be the starter...doesn't it?
With any DC motor, if tapping on it makes it go - it needs replaced- brushes are out of alignment to armature- due to wear. This applies to fuel pumps, wiper motors, window motors, starters, blower motors etc...Tapping on it centers brushes temporarily.....and is in itself a diagnostic tool to prove what is wrong and what needs replaced....used it for years- have started many a truck for others by beating on their gas tank- then told them to drive to the service center to replace their fuel pump.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 10-06-2015, 01:31 PM
gw84's Avatar
awesome, thank YOU!!
Old 10-06-2015, 02:08 PM
j cAT j cAT is offline
the starter does have brushes so tapping it may get it to work. I have found that the solenoid contacts do not last as long as the brushes in today's engines. since these engines have high voltage ignition systems. also a PCM that creates the perfect fuel mixture on any start this results in much less crank time so the brushes very rarely wear out before the solenoid fails or even the starter motor bushings.. The last time I ever seen brushes worn down was on a GM with distributor points and a carb. 30 plus years ago.
Old 12-29-2015, 01:37 PM
ASJT3 ASJT3 is offline
Send a message via AIM to ASJT3
I would agree with j_cat, corrosion is typical on these contacts and results in progressively poorer starting, although I have also seen it just abruptly stop working. Use a lot of dielectric grease on the new contacts
2008 Tahoe SSV, 2007 Tahoe SSV, 94 GMC K1500, 93 Chev K1500, 91 GMC K1500, 2000 Wrangler Sport
