Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 10-02-2015, 05:36 PM
windryder windryder is offline
Question Weird power Windows!
Owning a 2001 Lincoln LS sport 3.9 V8 has been interesting! Great car to learn how to diagnose problems. It seems every week there is a new issue with this car.
The latest problem is with the driver's side power window buttons and door lock! If I start the car, the driver side window buttons and door locks won't work! I can lean over and push the passengers window switch and it works fine. So does the lock switch. If I turn off the car
the switches work fine! I found that while driving if I "punch" the throttle the switches work fine! I get no check engine light, the alternator seems to be charging, no light. Battery is 6 months old. Is the car possessed? any thoughts?
Old 10-02-2015, 07:17 PM
MikeCStig MikeCStig is offline
Re: Weird power Windows!
Maybe a bad relay... Sometimes the problem with a car that has a lot of features (like a Lincoln) is there are a lot of things that can go wrong, so there are probably quite a few relays to check.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 10-02-2015, 10:55 PM
Your are probably right about a relay! The LS electrical system is over loaded, that's why it has a hydraulic cooling fan I read .
Tags
3.9v8 , lincolnls , switches , window
