Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 09-25-2015, 03:16 PM
LMP's Avatar
LMP LMP is offline
Massive coolant loss
....and now, a massive coolant loss, almost empties 1 gallon in minutes. Seems to come from feed pipe to heater near and slightly ahead of right wheel well. Will verify in a day or 2....
WIfe adamant that I must quit fixing......but I will prevail !
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 09-25-2015, 03:17 PM
LMP's Avatar
LMP LMP is offline
Re: Massive coolant loss
OK...coolant loss cause found: this is the "fitting, coolant bypass to intake manifold", part 162 at page 6A7-4 of the shop manual.
THis is a plastic fitting, and it is totally cut...will post a photo later.
AHh..this has been discussed before, begining at post #3 below
http://www.automotiveforums.com/vbul...d.php?t=771790
Old 09-25-2015, 03:33 PM
LMP's Avatar
LMP LMP is offline
OK...DORMAN replacement part number was in the former thread...asked the parts store here by the number and will get it tomorrow... C$ 9.00
Old 09-26-2015, 03:09 PM
LMP's Avatar
LMP LMP is offline
DOne. Back on the road. If you are still rolling a 3.8 and have not changed this plastic fitting for the metal one, do not get too far away. This is an easy repair that can save a lot of problems.
Old 10-06-2015, 01:01 AM
Jeffrv's Avatar
Jeffrv Jeffrv is offline
Lmp, I am surprised that plastic fitting lasted that long, 7 or 8 years appears to be the norm. Certainly that is when mine cracked.
Old 10-08-2015, 09:34 AM
LMP's Avatar
LMP LMP is offline
Maybe my low mileage can be a factor...after 22 years it has 190000 km (118000 miles) only. Since I had also another car, it has been hangared during a few winters, then saving cold/hot thermal shocks. I do not know if it was only cracked for some time cause I had to add coolant regularly, without being able to identify the origin of the leak. As said in the lionk dated 2007, the repair is easy, just putting the alternator aside without even touching the electrical connections. Removal of the broken part that was left in the threads of the manifold was not too difficult too: I forced a wood chisel straight into the plastic and then was able to uncrew . Just my aching back suffered a little....
Old 10-08-2015, 12:00 PM
Tech II Tech II is offline
LMP, that was a good trick for removal...
