Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 09-24-2015, 07:02 AM
jamesg1551 jamesg1551 is offline
fuel problems
have a 1994 gmc 1500, 4.3 engine. fuel supply problems. replaced pump with Delphi pump getting 2 second power to pump truck still will not start. could it be a relay problem or bad connection? please help. thanks james
Old 09-24-2015, 06:38 PM
maxwedge maxwedge is offline
A990 racer
Re: fuel problems
Basics, got spark, do the injectors spray when first cranking, will it start spraying carb cleaner into the intake?
Old 09-25-2015, 08:13 AM
Re: fuel problems
thanks for helping. have fuel at inlet line on back of tb. injectors not spraying. however I do not have spark. will injectors spray if I have no spark? thinking problem with spark to be coil or pcm. again thanks for help..james
Old 09-25-2015, 02:42 PM
A990 racer
Re: fuel problems
OK,power to the pump for prime, but does it run, if not check the ground side circuit to the pump.
