Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 09-23-2015, 02:47 PM
Guillaume777 Guillaume777 is offline
2005 Chevrolet Aveo - Timing Belt broke down
Unfortunately, the timing belt of my car broke down while driving on the interstate.
The mechanic said it would be $750 to fix the timing belt. However he said the engine is likely destroyed and we would probably have to replace it too.
What should I do? Should I cross my fingers and paid the $750 to replace the belt hoping it will work? Should I try to do the work myself ($750 seems a bit pricey to change the belt)? Or should I just give up on the car?
Old 09-23-2015, 03:34 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2005 Chevrolet Aveo - Timing Belt broke down
If the timing belt broke on the highway, you most likely bent several valves and possibly punched a hole in a piston. The head will need to come off to find out for sure what damage has been done. If you like the car, look around for a used engine, replace the timing belt and water pump on it and drive on! Still cheaper than a new car.
Old 07-11-2016, 02:10 PM
putnapomosht putnapomosht is offline
towing
