Old 09-22-2015, 11:45 AM
braek braek is offline
'99 Blazer S10 Front End Squeaking - TOTAL amateur with cars -
I have a 1999 Chevy Blazer, 4x4, and it is having a massive squeaking problem.
I am a complete amateur with cars, but need to get this thing fixed up for a cold winter with kids. I am worried about this squeaking because it doesn't sound like the brakes. It squeaks when I turn corners and when I brake or go over speed bumps.
I would not only like some opinion on what the issue could be, but how serious it is. I have read it may just be the ball joints that need greased (or replaced)?
And I need some insight as to whether I could do the work myself. I need to learn this stuff eventually!
Side Note: This may be important but almost didn't mention it because it is hellaciously embarrasing. I am worried this problem may have arisen from me not replacing the oil in a timely manner? I was checking the oil incorrectly for a time and thought that a smudge of oil on the dipstick was the oil line when it wasn't....it was bone dry on oil. Didn't kill the motor, but I have been keeping an eye out for problems from me driving without oil for however long I was. So embarrasing!!
Old 09-24-2015, 08:46 PM
NHRA's Avatar
NHRA NHRA is offline
Re: '99 Blazer S10 Front End Squeaking - TOTAL amateur with cars -
could be a arm bushing-control arm bushings upper or lowers?
Old 09-25-2015, 04:54 AM
MikeCStig MikeCStig is offline
I've seen this myself, and its common for control arm bushings to squeak on Blazers and S10s of that era. If it's just a squeak and not more of a groaning, grinding sound, it's not too serious yet, but you'll probably want to fix it anyway, that squeaky sound will drive you nuts.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Tags
blazer , chevrolet , squeaking
